Bimini top
The Daver
I would like to get a Bimini top for my boat. It's a 1995 Genesis 2001 Bow rider. My question is, should i have one custom made or are the aftermarket ones good enough?
southkogs
Welcome aboard:
For my money, if it's a bimini I would go with a standard that fit my boat. If it were a convertible top / rain cover, I'd probably look at something more custom made to my boat.
JASinIL2006
I got a really nice Carver bimini, made with Sunbrella, for my boat. You really just need to figure out how wide it should be, how long the supports should be (i.e., how much headroom is under it) and how long much of the boat (from fore to aft) you want covered. The length (fore to aft) will generally determine how many 'bows' (metal u-shaped bars) are needed to support it.
For mine, I determined the height by standing and measuring from the gunwales to the desired height of the bimini (giving me a couple inches of space above my head when standing). That worked pretty well.
The width is generally measured from gunwale to gunwale, across the the boat side to side. I went up to the next size so my bimini is just a bit wider than the actual boat; that provides a bit more shade when the sun is not directly overhead.
Length can be whatever you want. I measured mine to be long enough to cover the driver's seats and the rear bench seat, leaving the sunpad (in back) and the bow seating (in front), open for sunbathers. That lead me to a 3-bow bimini.
Most web sites that sell them (including iboats, I believe) have some instructions for measuring. You have some fudge factor to play with, so they are note super-critical measurements.
Texasmark
I wanted a Bimini for a Ranger Bass Boat. Since it was pretty peppy, I opted for SS tubing rather than Alum. that comes in most off the shelf kits. I had Alum. before and never tore one up. I should have listened to my experiences and had Alum. tubing on the custom job......way too heavy and pricy!
On another boat I had an Iboats OTShelf canopy.....about half the cost of the custom unit and every bit as fine a fabric, but with Alum tubing. Upon receiving, one of the bows was broken and it was not due to shipment as the box was in tact. I contacted Iboats, told them the problem and in a matter of a few days I had a complete frame assembly, not just the one that was damaged. I call that customer service!
Starcraft5834
Agree with JAS... before we got a new toon, i had a 20 ft cuddy... bought a Carver which was well made.... was very pleased with it just measure your beam width
JASinIL2006
Stainless steel tubes are definitely a plus, and, IMO, well worth the extra $$.
crazy charlie
If you are just looking to put something up and down to get out of the sun then you can do ok with the right size generic aftermarket.If you think you may want to eventually get side curtains or a back drop for it then have it custom made.
The Daver
Thanks for the information guys. I get nervous when it comes to measuring. I pretty much just want one for the sunshade. I have the original rain cover which is something I never want to use.
Stinnett21
Here's something to consider: Does your boat have a rain top currently? The one that connects to the windshield? If so consider getting a bimini that can stay erected without having to take it down and put up the rain top. I love boating and I live in Kentucky where storms can blow up unexpectedly so I frequently push the limits on the weather. Constantly having to switch covers is a PITA. With only slight difference in measurement I could have eliminated this issue. Also how will you store the bimini? Do you intend to leave it in the "arch" position when trailering? Unless it has has a cross support mechanism it won't ride well, will flop around on the road. Just things to think about.
Texasmark
On the where to put it, I like to keep mine at the stern where there is usually something upon which to place it, up off the deck, and thus keeps it from being "under your feet/in the way". Using rails for mounting the main structure are well worth the small price as you can pull it forward for attachment and when finished collapse it and push it to the stern and lay it down, out of your way.
