Bimini for Roswell tower
250Gimp
Hi All
I am trying to find a tower mounted Bimini for my Maxum 1800 SR3 with a Roswell tower.
I know Roswell makes one, but I cant justify over a grand for a bimini!
I have the original one for the boat, but it won't fit as it is too wide to pass through the tower.
Any suggestions would be greatly apreciated!
Cheers
CP
Skiya
Re: Bimini for Roswell tower
I put a Samson tower on my '07 210 Chaparral, one of the reason I went w/ Samson is I could keep my original bimini. I wasn't going to pay extra money for a bimini that would be smaller than the original. I had to modify the way I open it, it takes two of us now, but have the new procedure down now and is no big deal.
I don't know how your bimini is attached but mine is attached to the top of the windshield frame. With the bimini up and locked in to the rear support poles I pull the quick release pins on the windshield, drop the bimini down a little, unfurl it and then pin the bimini back in place. I thought it would be a big deal at first but it's not. And when I'm not using it I can strap it to the tower so it don't rock back and forth and put stress on the windshield mount. When I mounted my tower I positioned it w/ the bimini up.
250Gimp
Thanks Skiya!
My tower was already mounted when I bought it.
Maybe I will look into narrowing my factory bimini to fit.
Cheers
sickwilly
Would the Aerial tower bimni not bolt right over it?
250Gimp
I'll look into that one.
Thanks Willy!
pat8839
I ran into the same issue of not wanting to pay a fortune to use the factory bimini after adding a tower. I was able to use my factory bimini by cutting off 1in of each of the 6 legs for my bimini and now I can still use it. Just as Skiya mentioned though I also have to set it up in a different order than I did before, but I didn't have to pay extra money for a new one!
Good luck!
250Gimp
Thanks Pat
I will have to measure, as last time I physically tried to mount the bimini, it was too wide, but maybe lowering it will gain some room.
Thanks
250Gimp
Thanks ThreeMIle Bay
I will look into these.
They may work just right for me!!
Cheers
ThreeMileBayWaker
Once I get some spare cash layin around I'm planning on snagging the over/under style. I was quoted nearly a grand by the same company that did my entire bow and cockpit canvas which was only $800.... I told them that's astronomical and not good customer relations after already spending nearly a grand before. They also just sell the tower brackets to allow you to make one yourself if you felt crafty enough. I may also go this route too.
