I have a Maxum 2000 SR3 that has a bimini mounted to the window frame via ball socket mounts like these:
The screw has stripped the threads and is pulling out. I pulled it off and tried to tap it just a little larger, but the problem is that I can't use a larger screw cause the head won't seat itself into old screw recess as the head is too big. I ended up using headless hex screws
but they don't seem like they want to stay.
Is there another way to solve this problem? I feel like at some point the hole will just be too big and I don't see an alternative to fixing this.
