Bilge test
jarata
I have a 1993 yamaha 650 when i took it out last it filled with water in the engine compartment.Im assuming the bilge wasnt pumping the water and it went from front of jet ski overflowing into engine compartment.When i got home i sprayed water in the blow hole and alot of junk came out.
My question is is there a good way to clean it out and when im done is there
a good way to test out of water if the bilge is pumping right.Can you discoonect the tube for the blow hole.
Jeff Walkowiak
Re: Bilge test
it should not get water in there in the first place,, find the leak
