Re: bilge pump
don't get auto, get a float switch or a water sensor (needs wiped off on occasion) and ALSO have a switch on the dash to turn on manually in case the float or sensor fails.
^^^ This...
I run dual 800 GPH pumps as I wanted redundancy, and I boat on waters where I know I'm going to need to pump the boat from stuffing the bow into a wave, have done it all ready. (What would happen if a single pump failed or the hose clogged?)
I prefer a separate float switch as it's less expensive in the long run; pump $30, switch $20 or auto pump $50-60. I'd rather replace a $20 switch or $30 pump, compared to a $50-60 auto pump.
Also, make sure to wire it up so that pump will turn on automatically (connected direct to battery) and also turn on manually through a switch at the helm,,, 2 separate circuits.
Also (also), cheap corrugated bilge pump hose restricts flow, whereas smooth bore hose will flow a lot more water. It's not cheap though.
