Re: BILGE PUMP
Gabe,<br /><br />Take it out and make sure there is nothing jammed in it. That is not unusual for a new boat. There always seems to be some kind of junk left over in a new hull. <br /><br />Two wires vs. three wires. It depends on whether or not your pump is an automatic or not. If it had a three position switch, it will most likely have three wires.<br /><br />The new ones are easy to install. Most of the makers use the same color coding on the wire. If you buy the same brand, they will be the same.<br /><br />Might I suggest that if it does need a new one, GO BIGGER! This is one area boat makers scrimp. If it has a 500, go to a 750 or 1000, etc.
