Jerry San Diego
- Jul 18, 2003
- 48
I have searched this sit and found about 400 plus responses for bilge pump problems. However, I couldn't find one regarding my question. I hav a 21 foot 1989 Bayliner Trophy with a 3.0L engine and OMC Outdrive. The wiriing in the boat is a mess from previous owners attempts to rewire sever components.<br />I have three bilge pumps- Two in the enging compartment one forward of the engine(Rule 1500 GPH)and one at the rear of the engine Rule (700 GPH) with one float switch. In addittion there is one bilge pump in the front section of the boat with a 450 GpH and a Float switch. I discovered this pump has burned up leaving a hole burned in the cap of the motor. I have removed that pump and will be getting a new one today. Ther is one switch on the control panel for bilge pump- I believe this is the only manual switch for all three pumps. My question is- does each of the pumps and float switches have to have their own fuses? Is it appropriat for all three pumps to be on the same control panel switch? The two pumps in the engine compartment are running on the one float switch. Thanks for the help.<br />Jerry
