Bilge pump questions
tmcalavy
Need some advice on what kind/size bilge pump to put in the Texas Maid 15 foot aluminum runabout. Photo is attached. There is no bilge per se, just the space between the deck and hull (pretty shallow at the transom) and the drain hole is situated about 5 inches forward of the starboard corner of the transom.
Last time I took it out for a trial run to test the dual outboards, it shipped about 3 cups of water in about 2 hours so I know it leaks/seeps a little water.
I'm thinking a 500 to 750 gph pump centered on the transom at the back of the boat would work, wired to run automatically and plumbed to pump the water into the splash well or out over the transom (don't want to mess with any thru hull fittings).
Do you have to wire an automatic bilge pump to a switch or can it be wired directly with an in-line fuse on the hot wire? Don't really want to cut any holes in the dash for a switch if I can avoid it.
All of this brings me to ask, is a bilge pump really necessary on a boat this size? And what happened to the self bailer's you used to see...had one on my old 73 Ebbtide Lakemaster trihull that had a pickup/collector in the bilge well and the water went out a tube over the transom to an upright stainless tube that clamped to the cavitation plate on the outboard. This used the venturi effect to suck the bilge dry anytime the boat was moving.
I know you can pull the plug to accomplish the same thing while moving, but really don't want to mess with that as the fuel tanks and battery will keep the lateral bilge access panel weighted down.
This boat/rig will see service on inland canyon lakes in the southwest about 4 to 6 times a year, operating in open weather and relatively calm waters, on day fishing trips.
tashasdaddy
Re: Bilge pump questions
you are on the right track, get a 500-750 pump with the built in switch. inline fuse, as you said. i find the only problem to make sure it is working is to put water in the boat for it to pump out. the auto/manual pump has 3 wires, it is automatic, but has a switch to the dash if you need to manually turn it on, or to check it. this switch could be mounted anywhere out of site. it really is a convenience for your type boating.
k1w1t1m
I had to help a fellow Texas Maid owner out :)
I wired my bilge pump through an automatic switch direct to the battery. Here are a couple of pics
gunner1
Whatever size you choose remember this: the rated GPH is at the exit nozzle. If your thru hull fitting is three feet away, it'll be considerably less. For example I have a 16' aluminum boat that I installed a 1200 GPH bilge in. On the package, it said that while it was 1200 gph at the exit nozzle, three feet away it was only 900 gph. Which is about the actual size I wanted so it worked out fine. That's fifteen gallons a minute, or one gallon every four seconds.
