Re: Bilge Pump Question??
It's probably best to have the bilge pump on a seperate switch as well as wired with a float activating switch. The boat does not need to be running for your bilge pump to operate. As Hondon said, if it does happen to be wired through your ignition (which I would doubt) you would have to have the key on, but not actually run the engine.<br />my .02 hope it helps.<br />Fred
