Re: Bilge pump for Aristocraft 19
It looks like there is a place to put a bilge pump on the right side of the motor (165hp Mercruiser)
hum mj. which side would that be? port or starboard. right side could be either or depending on if yer looking fore or aft of the engine...
The one that came with the boat is just sitting behind the motor, has no float.
yep, that's the way mine was.
just glued to the inner liner. in between the drain hole and the aft hole coming from the ski locker.
Is there one that will fasten in the existing hole?
got pics. i don't understand what existing hole...
here was my answer as to where to remount my bilge pump.
the area i wanted to mount it at. paper towel in drain hole.
generally where i wanted the pump to be at...
my engineering. this is a coozy cup holder bent so the pump fits into it. then the mount handle of the holder was bolted to a piece of angle iron. the angle iron is bolted with one bolt to the inner gimble housing assy.. remove this bolt and remove whole assy.
the pump sits just above the liner. almost as low as possible. not glued to the liner which if ya would want to service the pump would make it near impossible to remove the pump. the one bolt idea i had makes it so i can remove it for service.
obviously, mine is not a auto pump.
doubt it's what it came with from the oem too.
i've tried to find out what it was like from the oem to no avail. i've never seen how one was mounted from the oem.
good luck with how you do it.
what i did is on it's 2nd year now. maybe third. so far it seems to work. granted. i think i've only seen water being pumped out once since install. at least i know it works. i just don't ever seem to get much water in my bilge. so far i've not needed it to pump.
