Trooper583
- Sep 19, 2010
- 134
Hey guys, quick question for all you experts out there. I have a 1995 Rinker 212 Open Bow. It has a Mayfair Marine 500 GPH bilge pump that works perfectly. I wanted to install an automatic float switch considering we will be leaving the boat in the water overnight some this summer.
I purchased a Johnson Pumps universal float switch from a local marina that was on sale.
I could post a pic but I think most of you can answer this question without it. My question is...Where do I mount that float switch? I want to make sure it is positioned correctly. The pump itself if centered in the bilge and located I would say just behind the front side of the block. Should I mount the switch forward of the pump? Also, should the float be facing aft or toward the rear? that is to say that the hinge would be pointing forward?
