Bilge Pump -Auto or???
dixon5553
Anyone know if a 2004 205 Sundowner has an automatic bilge pump, I believe it does but I don't see any mention of this in the Owner's Manual - thanks
Stinnett21
It's beneath your engine. Stick your phone down in there and video to get name/numbers, etc.
tpenfield
Automatic in the sense that it has a float switch to turn the pump on as needed . . . Yes, most/all boats have them. What is the nature of your question?
Chris1956
After 21 years, it most likely has been replaced at least once. Is it still an OEM model?
mr 88
Your bilge switch should be 3 way if installed by factory , off , on and automatic. Locate pump and look for float switch that should be very close to it . Some pumps don't have float switches , they are internal or have a water sensor in them ( dislike that style ,constantly running ) . Usually they are smaller volume pumps .
cyclops222
Is it colored RED, WHITE and BLUE ? Might be a Rule Computer controlled pump. They normally have 3 wires coming out. Computer dies after 2 summers of use. Faster if winterised with battery still connected.
