Bilge Cleaner and cleaning
agallant80
So perhaps its a pet peve of mine but does anyone out there clean their bilge every year during the layup process? If so any tricks/tips?
lakegeorge
Re: Bilge Cleaner and cleaning
At the end of the season you can dump a lot of Simple Green or another environment friendly cleaner in the bilge add water and go fo a bumpy ride. That will swish it around then run your brush over it and pump out.
That always worked for me.
agallant80
Yeah, after some further investigating I don't think this will be as complicated as I thought.
Home Cookin'
Or necessary. However, some people, concerned about mildew, are tempted to use chlorox--a bad idea b/c it is highly corrosive especially around aluminum. "Dry" is more important than "clean."
Grub54891
Heard a couple times to use powderd tide. Put it in the bilge,ride around,remove boat from water,drain and its clean. Never tried it myself though.
Grub
25thmustang
I cleaned the bilge on my last boat and kept up with it as best I could. Cleaned the bilge on the new boat but don't have the time to be down there scrubbing it. Not to mention its a stinky 30 year old bilge, so until I paint it, there's not much more I can do.
