purplesage
- Nov 10, 2010
- 35
This is the motor that had the thermal runaway. I tried to follow the advise I recieved on this forum. I rebuilt the water pump - changed the lube in the lower unit. I then filled a tank and started the motor. It ran well for about two minutes at approximately 600 rpm. The telltale was shooting water at a good rate and all seemed encouraging.
Then for what seemed to be no reason the motor backfired and stopped running. Now it will not turn over at all. It feels like for all intent and purpose that it is ceased.
I haven't pulled the head but I did pull the plugs and spray in some oil. The fuel was well mixed 50 to 1 and I had not shifted the motor.
Any thoughts or advice? Pretty discouraged at this point. Jon
