Re: Big Foot
What he said. But in addition, they were specifically designed for work boats and pontoons. A standard leg has 1.83:1 gear ratio which runs a 10 inch prop with about 13 pitch. A Big Foot motor runs the same lower unit that a 75-90 HP engine uses which requires a 13-1/4 x 15, 17, or 19P prop on a planing hull. It would likely be in the 14 x 9 or 11P on a pontoon or work boat. Since we have no idea what boat this engine is on we can't tell you if it is a good match or not.
