BF75L doesn't spit water
mike2004
Hello I have an older 7.5 Honda outboard that doesn't spit water. I recently bought the motor so I'm not sure if it ever spit water. The propellor has been replaced, and the thermostat was removed to try and just "flush water" through the system. However we still can't get water to come out the pee tube. Does anyone know if this is a common problem, or if most of the cooling water runs out through the exhaust?
zzzzz
Re: BF75L doesn't spit water
try some compressed air or a strong stream of water up the pee tube with the motor running to flush out anything that may be clogging it up :cool:
