1985 BF75FLA oil case seal for vertical shaft is leaking. I replaced it a couple of years ago along with an epoxy repair to a corrosion hole in the oil case. Had a bang of a time removing the vertical shaft from the crankshaft. Thought the seal would last longer than the epoxy repair, but no. The old seal was rusted and was destroyed in removal. This one still looks good but leaks. Are there any short cuts like adding an o-ring? Or what is the correct way to remove the seal. I remember the replacement had to be pounded into place.
