BF50A Speedometer Hookup
dougc21032
While placing the lower end back on my 99 honda bf50 I managed to have the plastic connector to the speedometer tubing break (at the bottom). It was capped off at the top and not in use, will it hurt to leave it open and not in use? I was in a time crunch so I just put the lower end back on, but it can be easily removed if I need to go back and cap off that spot. Wasn't sure if there was any need to install a new plastic nipple and reconnect the capped off line. Thanks
