After engine heats up steam starts coming from top exhaust port. Just replaced impeller that was missing 2 blades. Found some pieces in thermostat, Tell-tale and behind water Jacket cover. Blew air through tell-tell, thermostat opening and through bottom water tube. also water from hose through same areas. Oil Compression check was in spec. It steams alot more after coming off plane after a long run. then after idleing it lessen's. Is this normal? What could be the issue?
