I have a 1998ish BF25 that is struggling to idle. High throttle is fine. It really seems like junk clogging up the idle circuit. No problem, lets remove and clean the carbs.
With the design of this damn thing, you need to pull the entire intake/carb setup as an assembly, and then disassemble from there. I immediately tore the intake to block gasket, so I am sure the others will suffer a similar fate.
Does anyone make a gasket kit for this? (intake, silencer, 6 carb gaskets, and bowl gaskets). Just cleaning these carbs is turning into a pretty spendy endever. And I am going to have to wait on parts. Before I order from Honda, does sierra make a kit? I haven't run into one in my searches.
Thanks!
Rob
Thanks!
Rob
