Hello Me again.......<br /><br />When I mounted my 130, the directions indicated that the cavitation plate should be level with the hull line. However, when I run the boat with the trim more than 1/3 up, I believe the cavitation plate begins to scoop water and shoots it up the transom. At high speeds, so much water shoots upward that it begins to fill the back-wash area of the boat. I think all I need to do is raise the engine 1 or 2 notches. Anyone have any recommendations on how high I shoud go?<br /><br />Thanks
