Hi there,<br />I have a problem since Ive taken the lower unit off for an impellor-check: The motor starts up normal and revs up normal as well, but only without the cowl on! I recognized exhaust-smoke coming from out of the shaft where the shift rod goes down, so my guess is that the motor dies because of bad or no fresh air inside the motor, when the cowl has been put on and clamped tight. I couldnt find anything about how the exhaust works in the Honda-Manual, so I have no idea what went wrong when i put it back together? Any ideas?<br />Thank you already,<br />Rotty
