Rod Holder
- Jan 17, 2002
- 98
Hi,
I just sold my boat along with the 10 hp Honda that I really liked. I came across another motor the other day and I just had to buy it.
The guy said it was on a boat he bought and he did not need it (yadda-yadda). He said it bogged on acceleration when he tried to run it.
After getting it home, I went thru the carb (pretty clean) and checked the plugs (they were new, but had signs of several attempts to get it running)
I fired it up and it started right away, but sure as heck, it would not accelerate, just kinda boggs. It actually backfired out the carb.
This is a CDI ignition OB. Could this be weak ignition or possible someone had it apart and did not set the timing belt correctly ?
Does someone know how I can verify the timing (hard to eyeball as the cam is not directly aft of crank (slightly to one side)
Any advise would sure help !
RH
RH
