riverdog01
- Apr 21, 2010
- 48
I have a BF 9.9 BABS series which starts and runs fine when cold but sometimes when I run it for about 20 mins (happens more frequently after high speed it seems) it will stall out and won't start for about 20 mins. I just bought a shop manual and have just started checking the coils etc. not sure if my multimeter is wacko or if I really need the fluke 88 to get good readings. Pulser coil is giving me .39 @20K setting, primary Ignition coil is giving me .8 -.7 @200 setting, secondary is giving me 29.1 @200K setting.
I don't believe fuel supply is an issue but will be following up more on that when I can get it on the water. I'm in Canada so it won't be for another few weeks, I'd like to get as much done before I can get on the water as possible.
spec says should be:
Pulser 351-429 Ohm
Primary .35-.43 Ohm
Secondary 8.01-9.79 kOhm
Plugs are good.
I just ordered a new thermostat in case over heating is the problem, wondering if there is actually a sensor that will stop it from starting on this engine when it's too hot ? I do have the throttle limiter screw out so it will go faster than original 9.9 setting perhaps that is contributing to the heat issue.
Now that I have the shop manual, I think I know how to take the kill switch out of the equation, just disconnect one of the wire ?
Anything else I should be checking ?
Thanks in advance for any replies.
Pulser 351-429 Ohm
Primary .35-.43 Ohm
Plugs are good.
