Sylva-Ranger
- Jan 17, 2016
- 163
I every ones, English is not my langage but y will try to do my best to explain.
Honda BF-50d 50 hp 4 strokes Programmed Fuel Injection …………..Run OK for about 15 mins. than slow down and can't reach more than about 3800 to 4500 rmp
No light at ON the dash exept the green (ok) one. No check engine, overheat or low oil pressure light come ON when the troubles occur.
If you stop the engine and re-start, run good for some times and begin the same trouble……………….More the engine is warm and more the trouble come again quickly after you stop and re-start .
Sqeeze the primer bulb during engine running change anything.
the engine make that since about a month, new fuel in the tank change nothing, put a drop of Sea-Foam change anything.3 new spark-plugs change anyting.
Today i make a little tune-up : -Change the thermostat ans the impeller, both seems good.
-Adjust the valves, 2 of the exhaust just a little bit tight , adjust in the middle of the specs…
-Clean low pressure filter, Notting wrong , change the hi-pressure filter for maintenance but seems good to
-check code whith the jumper 070pz-zy30100 and have any codes in the memories.
I also check the 3 ignitions coil whit my ohmmeter, all 3 are in the specs (cold) , i take the fuel pumps pressure (cold)and in the specs (about 35psi).
Now i need to make a test on the lake, but i dont think the engine will be different because i don't find anyting wrong at the first view……..Probably bring a driver, my fuel pressure gage and my timing-light whit me the next time…..
Do you have idea ? Do you ever saw a similar problem on Honda engine like that ?
May thanks
May thanks
