buckbonzai
- Jul 13, 2012
- 1
I have a Honda BF40 BAYS3210. I re-built the carbs due to bad gas and now the motor will start but idle very rough. If I try to accelerate just a little, the motor dies even if I choke it a little.
I have done the following:
New fuel and oil filter
New fuel pump
New plugs
Good spark
Valve clearance OK
Fuel reaches all 3 carb bowls
Timing is correct
Pulser and exciter resistance OK
Any ideas?
New fuel pump
New plugs
Good spark
Valve clearance OK
Timing is correct
Any ideas?
