BF 150 SCS codes
hornblower4704
My Bf 150 is running poorly at idle. I've replaced all filters, new plugs, thermostats, MAP sensors, IAC valve. Actually swapped the MAP and IAC from my other BF 150. I have the SCS connector and I'm getting the following codes. 7 short blinks then pause long blink then pause 4 long blinks then 1 short. I have the shop manual but can't determine what problem the codes reflect. Any and all help is really appreciated.
Greg
ffengine28
Re: BF 150 SCS codes
I have a 2003 BF 150 with high hours and I am having the same problem. It seems like it is idled too low and stalls easy. I have a thread on hear about running Yamaha ring free through the motor because I was told it would clean a lot of carbon out of the motor, But I have not tried it yet. Hopefully somebody can help us.
hornblower4704
No, didn't replace the VST filter. Planning to try that this weekend. Thought about swapping the pump and VST from the other engine.
hornblower4704
Are you referring to the high pressure filter? Or is there a filter inside the VST?
ffengine28
There is one in the vapor separator. Go to ********** and they have great diagrams to look at. Look at the vapor separator diagram and you will see the one I am refering to.
