Re: BF 15 Balance Shaft alignment.
Thanks for the reply. There is a dot on each of the balance shafts but the crankshaft has what appear to be dots put there by someone else and not by Honda. These are lined up but the reason I ask is that it has what I think is a bad vibration. Not having anything to compare it to means I am a little in the dark. The motor will make the boat vibrate when it is up in the revs so much that it makes it rattle. Is that normal for a 1995 model 15hp Honda?
John
