Hello all, I've got a problem with a 130 that is hesitant to gain full speed when the throttle is moved from idle to WOT. It seems fine in any low speed range under 3000 rpm, but when the throttle is run to full, it slowly reacts and over 10 to 15 seconds will finally crawl up to 5000 or so.
I know the fuel system is clean and tight with the pressure as listed in the manual. The valves are set correctly and everything else is good. There are no trouble codes, alarms or other indicators that point to any specific area.
Any help would be greatly appreciated, Thanks
