BF 115 no compession
HD_Bob
I have a 22' Boston whaler with 2 BF 115s on it. I was told that one of them one day just wouldn't start. When I started checking I found no compression on all cylinders. Further investigating I found it has a new timing belt. Will this engine bend valves if the belt brakes or is installed wrong?
Thanks, Bob
Mas
Re: BF 115 no compession
Check your compression tester on the good motor.
MAS
Mas
I do not know your particular motor, but if you have zero clearance valves, like Honda did on some of their cars, the pistons will bend only the valves that are open at the time (been there done that). The ones that are closed will not open to bend because the belt broke. Now if you have zero clearance valves and the belt was reinstalled incorrectly, then conceivably, all your valves could be bent.
MAS
HD_Bob
Thanks for the reply. I checked the tester on the good motor it had 210 PSI. Here is what I found. Mud dobbers had built a nest on the crank pulley for the timing belt. When the motor was turned over it ran all that mess through the gear and belt filling in half of the teeth. This caused the belt to jump about 30* every revolution of the crank. When I found this I pulled the head and all 16 valves are bent. I just wasn't sure if this was an interference motor, now I know.
Thanks, Bob
Alumarine
Wow, good luck with that.
Those are nasty little things aren't they.
Mas
Replace the belt on a regular maintenance cycle. I'm not sure what that interval should be, but know that you'll be rebuilding the heads again if that $30 belt breaks.
PS Check for dobbers everyday???
MAS
