Best way to test power pack
surrender
1996 Johnson 88. What is the best way to test for proper output from power pack? CDI troubleshooting guide? Or spark tester
ezeke
Re: Best way to test power pack
The initial test of the ignition system was always done with a spark tester. That was followed by component tests if the spark test indicated a problem. Keeps it simple.
bktheking
Direct voltage adapter or meter that can do marine testing, stevens/merc o tronic.
SparkieBoat
google DVA adapter..they are about $35 and work with most modern multi meters...you can test volatge in from stator then voltage out from PP..this will isolate the problem.
