Hello, I've recently purchased a Rapid-O Marine long block with the cam upgrade. I would also like to add a new intake manifold, 600 cfm carb, and a new sets of manifolds. I know boats perform at a lower RPM range and was looking for advice on a manifold from someone with experiece on a similar remanufactured engine. What is my best bang for the buck; Edelbrock, Weiand, or Holley? Also, what finish would work best in my fresh water boat? I've been told to look into the Performer or Air Gap by Edelbrock but am open to hear other opinions.
Also, i'm willing to listen to your opinions on aftermarket replacement manifolds and a carb. I've heard the Edelbrock has a lot more parts, can be adjusted for midrange which can provide better fuel economy, and is cheaper. On the other hand i've heard the Holley is much easier to work on but is basically intended for WOT use. I will be using the boat recreationaly tubing, skiing, and cruising!
Thanks!
Thanks!
