Re: best rod holder for fly AND spin?
Well,every rod holder that I have seen the butt of the rod goes through a hole and leverage holds the rod in,the flyrod has a reel at the end and won't go through the hole for leverage.The Cabels 360 degree rod holder,if you stand the reel straight up in the air,turn your handle,if you got one to miss the sides will hold your flyrod.It will fit perfectly into the inside of the holder,but you will have no leverage.but the locking ring will hold your rod in there,and it will not go anywhere.Check it out,and twist your rod around until it fits perfectly inside the inside of the holder,it will only go in as far as the reel.otherwise the whole rod would just go through the whole contraption.
