Best placement of transducer
Stvpkr
Best place to mount transducer and plate? Or should I just leave the plate off and if so where to put transducer?
Ok it will not upload a pic from my iPad.
What kind of transducer, and what are we mounting it on?
Stvpkr
When I get off work il use my pc and see if I can upload a pic of the back of the boat.
Stvpkr
I am putting a lowrance fish finder on the boat.
Silvertip
You put the transducer where the owners manual tells you. That manual usually addresses the following:
​1) Right side of transom
2) specific projection below hull
3) As far from prop as possible
4) Not in line with anything under the boat (strakes, lines of rivets, etc.) that can create turbulence.
5) Specific cable routing and connections
Ned L
The most important thing is to place it in a clean flow of water ( nothing in front of it that will cause bubbles or turbulence).
