Gotta replace trailer springs, it's a small boat trailer with 13" wheels and has only two leafs on each spring. Where's the best place? Thanks.
Good idea. Going to have to re-place plates and all it looks like. The bottom plates are welded on . Axle is an oddball size.. 1 3/4 diameter. Spring length oddball size for a 2 leaf slipper.. 26". Spring eyelet hole measures 1/2" and about the only lenght's I found are 24 1/2 - 25" and the eyelet bolt hole's 9/16. Most plate kit's are for 2 3/8 size tube axles. About par for my luck when doing a project. Looks like once again a simple project gone awry with parts N/A and have to engineer "close" parts to work. Git 'er done!You could also try your local tractor supply store. they cary some trailer parts.
