Best oil to use
bamaeddie
Can i use regular car oil in my 170hp mercruiser inboard 1986 instaed of paying an arm and a leg for mercruiser oil .
erikgreen
Re: Best oil to use
(pulls out fire extinguisher and dons nomex suit)
bamaeddie
Re: Best oil to use
just asking a question but then you get some smart replies went to a dealer and hes said only mercruiser oil then i see different topics on the forum $5.50 for a quart of oil is alot dont you think.......
krisnowicki
Re: Best oil to use
I am curiuos as to what the difference is between the two?
Fishermark
Re: Best oil to use
bamaeddie - the answers are not directed toward you personally, it's just that whenever this question is brought up, there is usually a long drawn out discussion as to who uses what and why. Here's a recent post as an example. (It also contains a link to another example).
http://forums.iboats.com/showthread.php?t=274017
krisnowicki
Re: Best oil to use
after reading the other thread please in the interest or IO peace do not answer my question
JustJason
Re: Best oil to use
yes using automotive oil is fine. Just get the correct weight and use a brand name oil
HT32BSX115
Re: Best oil to use
;)Sorry! Couldn't help it.
Just do a search on this forum (or any boating forum) you'll get a ZILLION answers.
Far more than you'd get by asking the question (because the SAME question gets asked about once a WEEK......every week, every month over and over and over!)
Cheers,
Rick
Don S
Re: Best oil to use
I posted this about a 1000 times now, but here goes again.
If you aren't going to use what the Manufacturer recommends, the use whatever you want. Every oil out there has been used and recommended by someone.
Just change it (and the filter) every 100 hours or yearly as recommended and anything will work.
Read this from the Mercruiser website.
http://northamerica.mercurymarine.com/serviceandwarranty/mercruiserfaqs/fueloil.php
