Best method for push starting a boat.
  • Put the drive in gear and then get it up to speed.
    Votes: 12 26.7%
  • Get it up to speed and drop it in gear.
    Votes: 33 73.3%
  • Total voters
    45
Bubba1235
No longer on Forums
Which way would you do it?
Ok, it's still winter and I am bored to death! :D
QC
Re: Best method for push starting a boat.
Personally, I'd get a big crane and tow it up a waterfall. In gear of course.
rbh
HAHAHAHAHA, second or third gear before you dump the clutch. ;)
haulnazz15
Just wrap a pull-cord around the prop and put it in gear. Can't be too hard to pull start a Merc from the prop. :D
QC
Come to think of it, my method is pull starting. Never mind.
smokeonthewater
push start it in the ice... it's thicker than water so you get less slip and you can make frozen beverages with the newly chopped ice
mphy98
I would get the guide to spin the prop as fast as he could, then ram it into gear!
That's the redneck way! :eek:
Utahboatnut
Easy, remove belts wrap ski handle section around crank pully and let er rip. I pull started a 200 horse evinrude once does that count?
rjlipscomb
Can't you crank start it just like those old airplanes? :eek:
Ayuh,.... I'd Fix it,+ turn the Key....... :rolleyes:
Campylobacter
OK, that was weird, I just assumed I'd be the only voting. I'm in the majority tho! :D
BTMCB
It has been a long time since I last had to push start so I forget how the admiral did it. She was out of breathe tho.
QC
I tried to get Mrs. QC to hoist the boat up the waterfall, that's how I know you need a crane . . .
Yepblaze
Check your manual.
Don't be lazy or cheap.
Buy a manual.
And read it.
Triton II
Put a tyre around the prop and tow it with the leg lowered and the motor fully turned to starboard. Fix up a gravity feed waterline from a garbage bin to the muffs. Get tow vehicle up to speed and then ignition on, dump her into forward. Once started, select neutral and leg up. Let her warm up, tyre off and then and back her into the ramp.
PS: Practice first on someone else's! :)
kenmyfam
You are all incorrect.... you have to be on a lake with a slope on it and let it roll by itself downhill. Drop the clutch and away you go !!!!:D:D
rjlipscomb
Okay, I'm on a level lake and cannot just let it role down hill. So, where do I get a ... what? a TYRE? and tow whatever is around the prop with the... what lowered? the LEG? I think I get the rest of it. But I'm still so confused... I need a drink, a stiff drink. :D Thankfully it's still winter and I have time to figure this out.
Woodnaut
I can't believe I just sat here and read all of these. Aye carumba.
northernmerc
Just put a second motor that runs on the boat, get it up to speed, and then drop the clutch on the first motor. Easy as pie.
