best fuel for 1987 Force 125 hp
RGB4545
Just purchased a very nice used 1987 Bayliner Bass/Ski boat with a 125 HP Force. Suggestions on the best fuel reg or premium non ethanol :confused:
Mi duckdown
Re: best fuel for 1987 Force 125 hp
If the motor is also 1987. It was built to run on 87 10% ethanol
Jiggz
E10 or regular is just fine. There will be issues about E10 or using low octane gas but it is none issue.
jerryjerry05
Welcome,Profile,location?
You might be close to someone who can help.
Regular pump gas is fine.
Since it has ethanol in it, you'll probably need to change the hoses(if the previous owner hasn't)
Ethanol has a way of ruining the older hoses.
New to you?Compression test.Water sep filter?
Inline filter?
RGB4545
Thanks for all the replies. Sort of what I figured but wanted to check all the knowledge here on I boats. :)
gregmsr
Yes, check the knowledge....any Force 125 subject you are interested in.....search the forum and you shall find....
This forum has saved me hundreds of $$$!
Brianbull
I just purchased a 1986 Bayliner with a Force 125. It smokes a lot. I'm wondering if the previous owner used the proper 50-1 fueling. I'm newt o boating and worried this motor will cause me problems.
Jiggz
You opened an old thread. You will be better off starting your own thread and get quicker responses in return.
