best bearing grease
mrosedmd
i have a tandem disc brake trailer for a 2000 nitro 20' bass boat. i usually have the boat serviced but would like to take on some of the resposibility myself as i am not happy with the local dealer.
i am wandering what is the best type and orbrand of grease to use on the bearings and how often i should lube them?
not certain the dealer does it when he says and locked bearing can make for a short trip. thanks for your time.
bruceb58
Re: best bearing grease
I just use the sta-lube marine grease. It has worked fine for me for years. My boat and trailer is close to 7000# and I have disc brakes with no problems.
Mischief Managed
Any marine rated wheel bearing grease will be fine. You should be replacing it every year anyway.
