Just towed the boat back from KY to MO.<br /><br />Bent Spindle on the right side had the tire rubbing the trailer the entire way. Not much left of the tire, within miles of falling apart.<br /><br />Here's the question, Can I fix this without paying $150 for a new axel?<br /><br />I'm not afraid of fabrication, from what I can see, all this axel is is a piece of tube steel, with a spindle welded in each side, if this is the case, can I fix, or re-construc from scrach, weld on new spring plates and bolt up?
