Did a pressure test on the lower unit. Needed a new shift shaft seal. Installed a new one and still showed a leak out of the shift shaft seal with soapy water. Pulled the shift shaft out to take a closer look and noticed it was bent at the spot where the shaft goes into the seal. I’m assuming it’s NOT suppose to be like this….????
