Charger183
- Jun 25, 2002
- 57
I have just installed a set of Bennitt trim tabs to my boat. The joystick control and tabs work fine but the position indicators do not read a steady position. They both cycle from max 20 to 0 degs (and the LED bars also) continuously. I did not get any set-up instructions as this package was off an old boat, but assembled the wires color to color as one would expect. One thing though, there are 2 fused power leads (Orange and Pink) with 1 ground wire. Powering up the orange gave a light glow but no display, but you got bright display and the cycling when the Pink was also energized. On another site it showed 3 wires coming from the cylinders, these cylinders only had 2 each (2 red-2 green). I also followed the sites instructions on the initial set-up but still had the cycling problem. I took the electronics box apart but found no poor solder joints or GREEN DISEASE. Any help would be appreciated. Larry
