Bennett trim tab won't calibrate
Bigdrago
Hi.
i replaced both trim tab upper hinge because one sensor didn't work.
After replacing them I need to calibrate them.on the eic5000 panel. Port and starboard red led flash alternately.
i press the sun and moon for 3 seconds. I press both tabs down. But the port and starboard upper yellow dont starr to flash.
When connecting new hinge with sensor I installed the old connector on the new wire so that I could connect it to the relay unit . Maybe I switched the + and - cable from the sensor?
