Below 32 degrees, what problem can i run into comments... Please
rocket rich
I leave my boat in the water till it starts to freeze. With the motor on full tilt out of the water and raining some time can it freeze up??? or what problems can I run into with my new Tohatsu 9.8 A3:blue::grumpy:
Georgesalmon
Re: Below 32 degrees, what problem can i run into comments... Please
yup, leave it down so the water can all drain out of the power head.
pvanv
Any tilted OB (if equipped with thru-hub exhaust) can accumulate rainwater in the prop hub and LU exhaust passage. That water can freeze, and break the LU housings. Keep it tilted down if you expect freezing.
rocket rich
Thanks again , Paul. I'm just not use to this motor yet... I did that with my old motor..
