Bellows
atmeiners
I am replacing my bellows on a Alpha One Gen. 2 and i just pulled the gimbal bearing and replaced it last night. I purchased a transom repair kit but I believe they shorted me a hose clamp. I just don't remember if there were two hose clamps on the upper larger bellows. If someone would could let me know thanks.
JB
Re: Bellows
Well, the question you didn't ask is, "Is my Alpha 1 Gen 2 and OUTBOARD?"
No, it isn't. It is an I/O.
I will move this for you.
Good luck. :)
tinknocker07
Re: Bellows
Look at the new bellows is there on or two places on the same end
molded in the rubber for clamps they come eather way!!
Nate
Re: Bellows
Ayuh,......
I think the Gen.IIs use a Ring that is pushed in the bellows to hold the transom end....
atmeiners
Re: Bellows
I do have the ring and you believe it goes to the transom end? Thats towards the boat but this picture shows that the ring faces the back of the boat.
Andrew.
Thanks for the help.
