My boat currently has an OMC 185hp(305) engine(inboard with a BW velvet drive.
I am planning on replacing the engine withing the next couple of months. Before I do this I have several questions that the experienced hopefully can help with, so here goes...
1. I want to change to a GM 350 (5.7). I will be purchasing a long block from a reputible rebuilder (suggestions appreciated). I have been told that ALL parts from the 305 will bolt to the 350 such as water pumps, intake, distributor, oil pan, etc. Is this true?
2. The engine is a 1979 and has a 2 piece oil seal. I understand that the difference is the crank bolt pattern and a later model (post 1979) will not bolt up to my velvet drive. Is this true?
3. My engine has a port side Oil pan.(the dipstick is on the port side). Until today I didn't realize that there was a difference and assumed that that was determined by the oil pan alone. Is there really any difference between the engines that would cause this to be an issue?
4. What would be the advantage to replacing the stock manifold with a manifold of Higher performance in this case? This boat is used mostly for fishing and cruising, but occasionally we pull a tube or skiier.
5. I will be replacing the "log style" rear exit exhaust manifolds with new. These are quite expensive compared to the VP or mercruiser manifolds. Is it possible to change these manifolds to the VP (or mercruiser) style manifolds without damage to my new engine?
Thanks again for your opinions and Info.
mlaymance
mlaymance
