I have only had our new boat (38 year old 15ft tri-hull) out one real time but am very eager to take it out again the minute I have the time. Before I take it out I wanted to try and address the slow speed porpoising which makes it very difficult to see over the bow and uncomfortable all around. At high speed (3/4 throttle and up) it is fine and does not bounce etc. but if I am trying to go slow as in fog and maintain around 1/3 throttle it just goes up in the air and when I let off the throttle the water comes a bit over the stern. So in the fog I can either not see over the bow or go too fast to see anyway.
My question is this...I bought a hydrofoil to try but when I noticed the existing holes did not line up I thought I would make sure I needed one of these before drilling another set of holes. That being said this boat did have a fin of some kind installed at one point. This motor came with the boat I believe since I got the owners manuals etc. from the original owners family member
BUT...maybe I am just overweight on the stern since I have two full tanks (6 gallons each) two batteries a 50 HP and a 10 HP kicker....if that's the case will the hydrofoil still work?
I am not sure how else to load the boat since the stern is where all this stuff needs to be while trolling.
The boat is rated for up to 85 HP.
Also...my prop has one fin that looks to have hit a rock or something and is bent over and tore about a half inch...would this cause anything undesirable? Would I notice a difference with a new prop?
Thank you.
Thank you.
