Re: bearing removal?
There is a gap between the inner seal,the race, and the bearing, and the seal is the only one holding the bearing inside. Using a long stick, like a chopstick but may 1/2" wide and flat oat the end (do not use metal tip), lightly punch on the side of the bearing until it swings out or in. Do not punch on the bearing's rollers. When you punch the bearing's side, it will fight itself out of the seal. When the bearing has swung, from here, you will be able to see the innner side of the seal. Use a huge flat screwdriver and hit the seal several times until it comes off. The seal will be practically destroyed. It does not matter. Just get the seal out of there. The bearing will come out.
