While removing the dust cap to check the bearings on my trailer, I noticed a small hole had somehow gotten punched in the cap. Once off, I saw some rusty residue inside the hub. After cleaning and repacking, I replaced the cap as I couldn't get a replacement that late at night. Should I replace the cap before submerging the trailer again, or is there no need to be in a hurry? Also, does this seal the bearing area to make it completely watertight. In case you hadn't guessed, I'm a novice! Thanks for any help.
