I have an '89 Calkins dual axel trailer. I went in to replace the bearings in the front axel and found the inside bearing completely destroyed. All that was left were the actual rollers floating around and the part of the bearing that contacts the spindle was apparently fused to the spindle. I ended up removing that by tapping with a chisel from behind. I had to remove the hub from the rear axel so I could use that inside bearing to ensure I got the right one from the parts store. With the exact parts I easily redid the entire rear axel hub but when I went to complete the front axel hub it wouldn't slide all the way on to the spindle. (about a half inch short) There are definately some imperfections on the spindle. I've been trying to smooth them with emory cloth and have had a little luck but not much. Is my spindle damaged from the bearing being fused to it from the heat? Anyone seen anything like this before? Help!
